Not sure if this is possible, but asking if a "wise one" can enlighten me.
I use bash.
I have defined the following two aliases:
alias ndate="awk '{ pos=index( \$0, \$9 ) ; rem=substr( \$0, pos ) ; printf(\"%s %3d %10s %10s %10d %3s %2d %5s %s\n\", \$1, \$2, \$3, \$4, \$5, \$6, \$7, \$8, rem ) ; } ' "
alias lsh='find . -maxdepth 1 \( ! -type d \) -print | cut -c3- | sort -V | xargs -I here ls -ld --color=auto "here" | ndate '
Unfortunately, the colour from "ls -ld" does not survive the awk post-processing.
Is there an option for awk that would recognize and preserve such colour codes and pass them thru?
After digging further afield, it turns out that the issue was the wrong choice of option for the --color switch.
Replacing "auto" by "always" was what I needed to ensure the colors weren't suppressed if passed on to a pipe. (don't I feel stupid! )
For those who are interested, here is the full set of special "aliases" that I have for bash. Enjoy!
These are added to my .bashrc-local file:
### Define various aliases
echo -e " alias ndate = awk '{ pos=index( \$0, \$9 ) ; rem=substr( \$0, pos ) ; printf(\"%s %3d %10s %10s %10d %3s %2d %5s %s\n\", \$1, \$2, \$3, \$4, \$5, \$6, \$7, \$8, rem ) ; } ' "
COM='find . -maxdepth 1 -type d -print | cut -c3- | sort -V | xargs -I here ls -d -1 "here" '
echo -e " alias lsdir = ${COM} "
alias lsdir="${COM}"
COM='find . -maxdepth 1 -type d -print | cut -c3- | sort -V | xargs -I here ls -ld --color=always "here" | ndate '
echo -e " alias ldir = ${COM} "
alias ldir="${COM}"
COM='find . -maxdepth 1 \( ! -type d \) -print | cut -c3- | sort -V | xargs -I here ls -d -1 "here" '
echo -e " alias lsf = ${COM} "
alias lsf="${COM}"
COM='find . -maxdepth 1 \( ! -type d \) -print | cut -c3- | sort -V | xargs -I here ls -ld --color=always "here" | ndate '
echo -e " alias lf = ${COM} "
alias lf="${COM}"
COM='find . -maxdepth 1 \( -name "*.sh" -o -name "*.bash" \) -print | cut -c3- | sort -V | xargs -I here ls -ld --color=always "here" | ndate '
echo -e " alias lsh = ${COM} "
eval alias lsh='${COM}'
Just make sure that your .bashrc contains a line
. ~/.bashrc-local
