Is there some way to make the mouse pointer larger
Is there some way to make the mouse pointer larger? It’s kind of getting lost on a screen the size of my main screen. Thank you in advance!
Right click on the desktop. Choose “Change Desktop Background”. Under the Theme tab choose Customize… . Under the Pointer tab at the bottom you have a slider to change the size of the pointer.
