I decide to install 24.04 on a test box and have two issues.
One Caja doesn't show album art (thumbnails) on my songs and I do a lot with music. If I open the folder/album in Thunar they show, and then will show in Caja after that.
after opening with Thunar
I went to my Mint Mate and added any thumbnail software that Ubuntu Mate didn't have but still get the same result, album art won't show if I don't open it in Thunar first. This was a problem in 20.04 LTS, solved in 22.04 LTS and back again in 24.04 LTS. Any suggestions?
The second problem is with engrampa. It will compress a file, but when I try to extract nothing is there. I added gnome file roller and when I try to extract the file is there and extracts correctly. I usually use .7z, as you can password protect the compression for privacy. I also tried in different .tar compressions with the same results. Then I added gnome file roller and that finds and extracts the file correctly.
This is a new problem I have only experienced in 24.04 LTS. Again anyone having this same problem. Any ideas?
I would like to put Ubuntu Mate 24.04 LTS on my main laptop and register it with Ubuntu Pro, but not until I can fix these two problems. Does anyone know when the next point release will be ready?
