Hello, this is my first time with mate. I have a problem that I can not solve. None in the program installs. Can someone help me?
obs: sorry for the mistake. I am not fluent in English. Brazilian.
how are you trying to install software, through the software boutique ?
It’s possible dpkg problem, but i’m not sure. Try to describe your problem, maybe you have error log?
Hi, I’m trying to install by the program center, provided by the boutique itself. the only error message that appears and that could not be installed, in addition the process bar reaches 15% and returns to 0, progesseguindo normally until the massage of error.
can you install programs from the command line using apt
