Hello, I have a problem with the AutoFirma program (in Spain it is used to operate electronically with the administrations, specifically to sign documents and processes). Both with Mozilla, Chrome and Chromium, it gives an error "java.util.concurrent.TimeoutException" but only in certain processes, generally the final ones. I use openjdk-11-jre (the recommended version).
Thank you.
