JSON reader/interpreter/converter
I posted this here in because I don't really think this is a help topic, but merely looking for suggestions and/or recommendations.
Using czkawka (a wonderful tool for locating duplicate files) I wound up with a large set of data that when saved results in a JSON file. I know that programming tools like geany can read and "beautify" JSON files, but I'm hoping to extract simply the full path of each file and write it out to another (hopefully text) file, so I can then review the duplicates and decide on a pruning method.
I'm thinking the simplest, although not necessrily the easiest method, is to use sed to write out the line containing the "path" specification to a text file, but I wonder if there are automated tools that can do this?
I am not a javascript programmer, so native JSON doesn't do much for me. Reading a large (5.7Mb) file line by line just seems inefficient and time-consuming.
Any suggestions?
P.S. I know I can do this with both grep and sed because I've tried both, but is there an easier way?
May be czkawka GUI is more convenient than .json for your purposes
LOL! We now come full circle. As I mentioned in my OP, I used czkawka to discover my duplicates. :slight_smile:
What I did was save the output which in "pretty" JSON format is 5.7MB in size. That's 28,786 lines! But I don't need the JSON formatting, all I need is the path-file information.
I have actually accomplished my goal by using sed (grep is faster, but sed lets me use a single command). All I care about are image (.jpg) files, so I used
sed -n '/path/ { /jpg/ p }' input_file > output_file
If you are interested, the following is a tool which can assist, depending on how much of the "obfuscated" output you want to be able to read, interpret, parse or process. :slight_smile:
Script "USER__CODE__ReFormatPretty.sh":
#!/bin/bash
###	Hack for attempt at de-obfuscating javascript, css, and similarly formatted files
###	Intended to insert newline at evey semicolon and opening and closing brace
###	Open brace triggers indentation action until closing brace reduces indentation amount
prettify()
	awk '{
		gsub(/[;]/,";\n") ;
		gsub(/[{]/,"{\n") ;
		gsub(/[}]/,"\n}\n") ;
		gsub(/[[<][Aa]/,"\n<a") ;
		gsub(/[[<][Dd][Ii][Vv]/,"\n<div") ;
		gsub(/[[<][Uu][Ll]/,"\n<ul") ;
		gsub(/[[<][Ll][Ii]/,"\n<li") ;
		gsub(/[[<][Ss][Pp][Aa][Nn]/,"\n<span") ;
		gsub(/[[<][/][Aa]/,"\n</a") ;
		gsub(/[[<][/][Uu][Ll]/,"\n</ul") ;
		gsub(/[[<][/][Ll][Ii]/,"\n</li") ;
		gsub(/[[<][/][Dd][Ii][Vv]/,"\n</div") ;
		gsub(/[[<][/][Ss][Pp][Aa][Nn]/,"\n</span") ;
		print $0 ;
	awk -v dbg=${debug} 'BEGIN{
		indent=0 ;
		if( $1 == "}" ){
			indent-- ;
			if( indent == -1 ){
				indent++ ;
				if( dbg ==1 ){ print indent, NR | "cat 1>&2" ; } ;
			}else{
				if( dbg ==1 ){ print indent | "cat 1>&2" ; } ;
		if( indent == 0 ){
			print $0 ;
		}else{
			for( i=1 ; i <= indent ; i++ ){
				printf("\t") ;
			print $0 ;
		if( index($0,"{") > 0 ){
			indent++ ;
			if( dbg == 1 ){ print indent | "cat 1>&2" ; } ;
PIPE=0
while [ $# -gt 0 ]
do
	case $1 in
		--stream ) PIPE=1 ; shift ;;
		--file )   PIPE=0 ; INPUT="$2" ; shift ; shift ;;
		* ) printf "\n\t Invalid option provided on the command line.  Only available: [ --stream | --file {filename} ]\n\n" ; exit 1 ;;
	esac
done
if [ ${PIPE} -eq 1 ]
then
	prettify
else
	prettify < ${INPUT}
fi
exit
LOL!
That reminds me of the winning entry in a 1988 International Obfuscated C Code Contest, authored by Ian Phillipps.
main(t,_,a) char *a; { return!0<t?t<3?main(-79,-13,a+main(-87,1-_,main(-86,0,a+1)+a)): 1,t<_?main(t+1,_,a):3,main(-94,-27+t,a)&&t==2?_<13? main(2,_+1,"%s %d %d\\n"):9:16:t<0?t<-72?main(_,t, "@n\'+,#\'/*{}w+/w#cdnr/+,{}r/*de}+,/*{*+,/w{%+,/w#q#n+,/#{l+,/n{n+,/+#n+,/#\\n;#q#n+,/+k#;*+,/\'r :\'d*\'3,}{w+K w\'K:\'+}e#\';dq#\'l \\q#\'+d\'K#!/+k#;q#\'r}eKK#}w\'r}eKK{nl]\'/#;#q#n\'){)#}w\'){){nl]\'/+#n\';d}rw\' i;# \$${nl]!/n{n#\'; r{#w\'r nc{nl]\'/#{l,+\'K {rw\' iK{;[{nl]\'/w#q#n\'wk nw\' \\iwk{KK{nl]!/w{%\'l##w#\' i; :{nl]\'/*{q#\'ld;r\'}{nlwb!/*de}\'c \\;;{nl\'-{}rw]\'/+,}##\'*}#nc,\',#nw]\'/+kd\'+e}+;#\'rdq#w! nr\'/ \') }+}{rl#\'{n\' \')# \\}\'+}##(!!/") :t<-50?_==*a?putchar(31[a]):main(-65,_,a+1):main((*a==\'/\')+t,_,a+1) :0<t?main(2,2,"%s"):*a==\'/\'||main(0,main(-61,*a, "!ek;dc i@bK\'(q)-[w]*%n+r3#l,{}:\\nuwloca-O;m .vpbks,fxntdCeghiry"),a+1); }
Compile and run it .
Or not. C compilers and the code have evolved over the past 35 years, so I'll tell you what it did: It printed out the full "12 Days of Christmas" song.
Merry Christmas!
(P.S. You can find out more, including the formatted code, here)
