Just saw that in Synaptic
that there is UbuntuMate Cloudtop and UbuntuMate Minimal options!
Are these only for 15.04 and up or can they be for 14.04?
Also how do I get one of these set up? Install one then uninstall the UbuntuMate Desktop? Would love to try out that cloudtop version for my server.
ubuntu-mate-desktop is a meta image, it wouldn’t uninstall existing packages. You could give it a test run by installing Ubuntu MATE from scratch, or have Ubuntu Server as a base.
@wimpy wrote how to achieve this with 14.04, instructions for 15.10 should be fairly similar:
Instead of the full desktop, try ubuntu-mate-cloudtop. This looks new, so I suggest giving it a test run first! :slight_smile:
I’ve got the mini iso installing as I type this.
I’ll see if the ubuntu-mate-cloudtop will work
@UnkleBonehead Do not forget the ^ at the end of a meta-package :slight_smile:
Well it worked. But the motherboard on that computer fried.
I dont think that they are supposed make a popping sound and then you see and smell smoke.
Dammit!
At least I my new Chromebook showed up this week!
