I am on the current updated version of Ubuntu Mate 17.04. I installed Kdenlive from the Software boutique and cannot get it to launch from the menu. Launching it from a terminal yields:
Invalid Context= "Mimetypes" line for icon theme: "/usr/share/icons/Faba/symbolic/mimetypes/"
(kdenlive:24393): GLib-GObject-WARNING **: cannot register existing type 'GdkDisplayManager'
(kdenlive:24393): GLib-CRITICAL **: g_once_init_leave: assertion 'result != 0' failed
(kdenlive:24393): GLib-GObject-CRITICAL **: g_object_new: assertion 'G_TYPE_IS_OBJECT (object_type)' failed
(kdenlive:24393): GLib-GObject-WARNING **: invalid (NULL) pointer instance
(kdenlive:24393): GLib-GObject-CRITICAL **: g_signal_connect_data: assertion 'G_TYPE_CHECK_INSTANCE (instance)' failed
(kdenlive:24393): GLib-GObject-WARNING **: cannot register existing type 'GdkDisplay'
(kdenlive:24393): GLib-GObject-CRITICAL **: g_type_register_static: assertion 'parent_type > 0' failed
Segmentation fault (core dumped)
Can anyone shed some light on this and how to fix it?
