Kernal issue on Raspberry Pi 2
Hi all
I’m having an issue where I can’t seem to get Ubuntu MATE to work on my Pi. So far I’ve tried installing it onto 2 separate microSD cards, via 2 separate computers using 2 separate methods (usb card reader and sd adapter) and downloading from both the torrents and direct download.
I’ve also tested both cards with Raspbian of which both worked so it’s not the Pi nor the card.
Anyone got any ideas as to what I should try next?
Here’s a photo of the error I’m getting http://imgur.com/a/UTUhM
Thanks in advance
