On a Pi 3, it’s the second time i get a problem, although i don’t remember if the first time was a kernel panic too… But in both cases i used BerryBoot to install Mate 15.04 on a HDD and then upgraded. This time i got a kernel panic, and i barely installed a few packages…
I wonder if the upgrade to 16.04 could have had an incompatibility with BerryBoot on Pi…?
(Or if something else went wrong…)
Edit: i think there’s indeed a problem between Mate and BerryBoot, 'cause i can’t boot either on Raspbian installed on the same disk, i get a kernel panic too. The previous time both install failed at the same time too.
