Hi I am strongly considering installing u.mate for all the obvious reasons.
Will the keyboard shortcuts / customisations below (the three URL’s) work in u.mate also, or are they only for other DE’s? So I don’t spend unnecessary time trying to make them work. I prefer the keyboard due to RSI.
Apologies if this question is very broad. Mainly I want to customise the keyboard to send keystrokes, except if a similar one already exists. So that I can avoid using the mouse as much as possible. The one I usually define first of all is to let numeric keypad ‘5’ (when numlock is off) generate a simple left mouse click. But I invariably create many others also.
Say if you have a better solution or download. This will be my first Linux distro, so your patience is appreciated… Thank you!
https://help.ubuntu.com/stable/ubuntu-help/shell-keyboard-shortcuts.html
For all users
https://help.ubuntu.com/stable/ubuntu-help/keyboard-nav.html
For users who want to use the keyboard as much as possible.
changing keybindings yourself
(There are many options here, you can just reply on those you know about)
