I have installed kodi using the apt-get on mate 15.10 but when I try to run I keep getting the following error message :
“/usr/lib/kodi/kodi-xrandr: Failed to get size of gamma for output default
libEGL warning: DRI2: failed to authenticate
Segmentation fault (core dumped)”.
I am using the analogic video output with the RCA cables.
I saw here someone having the same problem but it was using HDMI cables and to solve it just hat to define the resolution in hdmi_mode in the config.txt file
