When installing kodi using shell the below error occurs, I realize that and dependency, I installed several PPAs but without success see the dependency:
apt install kodi -f -y
Reading package lists... Done
Building dependency tree
Some packages could not be installed. This may mean that you have
requested an impossible situation or if you are using the unstable
distribution that some required packages have not yet been created
or been moved out of Incoming.
The following information may help to resolve the situation:
kodi : Depends: kodi-bin (>= 2:16.1~git20160425.1001-final-0xenial) but 2:16.0+git20160228.1453-final-0~xenial2.1 is to be installed
Recommends:
libva-intel-vaapi-driver but it is not installable or
i965-va-driver but it is not installable
My configuration
Release 16.04.1 LTS (Xenial Xerus) 32-bit
Kernel Linux 4.9.5-v7+ armv7l
MATE 1.16.1
