Ktechlab on Ubuntu MATE
Hi
I've got a problem with Ktechlab electronic simulator.I am trying to install, but it says that dependency is not satisfiable(it is kdelibs4c2a) So can that dependency install force or need newer version on Ktechlab?
Thanks in advance.
go here:
http://pkgs.org/search/kdelibs4c2a
and select the package you want, it will then take you to another page where you can check out the various packages, I am not sure if this is what you are looking for though!. :wink:
No, it doesn’t work. Does somewhere exist package for running all kde apps like ktechlab?
Hi MATE,
take a look here for an alternative:
http://sourceforge.net/directory/science-engineering/eda/os:linux/freshness:recently-updated/
You can download their tar package from here and install it that way (please don't ask me how!):
The above package is 2 years old and I don't know whether it will be supported on later versions of Ubuntu?.
There are no downloads available on Launchpad:
https://launchpad.net/ubuntu/trusty/+source/ktechlab
I already read that.
To sum up, this application can’t be installed anymore, I will try to find an alternative, thank you anyway.
Bom dia,
Eu também não consegui instalar o Ktechlab no Ubuntu 14.04. Para resolver este problema eu instalei o Ktechlab em um chroot e compactei e gerei um script de instalação. Todo o processo de instalação está no video abaixo. Testei no Ubuntu 14.04 e funcionou. Tente no MATE para ver se da certo.
Link: https://youtu.be/VpNb2SzYOXw
Boa sorte.
Hello, your version of Ktechlab is working perfectly.
Thank you SIR.
Bom dia,
Obrigado por testar sobre o MATE. Que bom que deu certo.
:grinning:
Bem bacana a forma do chroot, ( como come um espaço enorme ) eu uso o ktechlab normalmente no GNU/Linux KDu basead no ubuntu 14.04 sem uso do chroot…mas precisa instalar a lib kdelibs4c2a_3.5.10 e isto me força a não ter o kolourpaint4 que faço uso constantemente e assim tenho de optar usar o ktechlab ou o kolourpaint4 ambos tenho necessidade, posso montar um script para desativar a lib e usar o ktechlab depois reativar e usar o kolourpaint4…mas ainda estou verificando como dar uma solução para isto…no mais o ktechlab roda normalmente forçando a instalação das suas dependencias…
Esta lib precisa de outros complementos mas faceis de se rem instalados…como menu-xdg e liblua , liblualib…mas depois de instalar , o ktechlab roda normal ate onde testei e uso.
att.
SuporteTecnicoID
