I printed an Avery 5160 label.
All the text was within the borders. (On the screen)
However, it printed the labels too low ruining the labels.
What can I do the fix that ?
I also tried Glabels, but it was no better.
Hallo fixit7
I use “glabels”. I do not use “brand” labels and had to go through a process of trial-and-error before I got the setup right.
Which program did you use (first part of your report) before you tried glabels?
I tried LibreWriter.
I never had an problem printing labels when I was using XP.
