@Philippe thank you for reply :
lsusb -t
/:  Bus 001.Port 001: Dev 001, Class=root_hub, Driver=xhci_hcd/4p, 480M
|__ Port 001: Dev 002, If 0, Class=Hub, Driver=hub/4p, 480M
|__ Port 002: Dev 003, If 0, Class=Hub, Driver=hub/4p, 480M
/:  Bus 002.Port 001: Dev 001, Class=root_hub, Driver=xhci_hcd/4p, 10000M
|__ Port 001: Dev 002, If 0, Class=Hub, Driver=hub/4p, 5000M
|__ Port 003: Dev 004, If 0, Class=Vendor Specific Class, Driver=r8152, 5000M
|__ Port 002: Dev 003, If 0, Class=Hub, Driver=hub/4p, 5000M
|__ Port 001: Dev 005, If 0, Class=Mass Storage, Driver=usb-storage, 5000M
|__ Port 002: Dev 006, If 0, Class=Mass Storage, Driver=uas, 5000M
|__ Port 003: Dev 007, If 0, Class=Mass Storage, Driver=usb-storage, 5000M
|__ Port 004: Dev 008, If 0, Class=Mass Storage, Driver=usb-storage, 5000M
/:  Bus 003.Port 001: Dev 001, Class=root_hub, Driver=xhci_hcd/2p, 480M
|__ Port 001: Dev 002, If 0, Class=Vendor Specific Class, Driver=rtsx_usb, 480M
|__ Port 001: Dev 004, If 0, Class=Wireless, Driver=btusb, 12M
|__ Port 001: Dev 004, If 1, Class=Wireless, Driver=btusb, 12M
|__ Port 002: Dev 005, If 0, Class=Video, Driver=uvcvideo, 480M
|__ Port 002: Dev 005, If 1, Class=Video, Driver=uvcvideo, 480M
/:  Bus 004.Port 001: Dev 001, Class=root_hub, Driver=xhci_hcd/1p, 10000M
sudo dmesg | grep -i usb :
[    0.336407] ACPI: bus type USB registered
[    0.336428] usbcore: registered new interface driver usbfs
[    0.336437] usbcore: registered new interface driver hub
[    0.336453] usbcore: registered new device driver usb
[    0.913312] xhci_hcd 0000:03:00.3: new USB bus registered, assigned bus number 1
[    0.915982] xhci_hcd 0000:03:00.3: new USB bus registered, assigned bus number 2
[    0.915996] xhci_hcd 0000:03:00.3: Host supports USB 3.1 Enhanced SuperSpeed
[    0.917238] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 6.08
[    0.917248] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    0.917253] usb usb1: Product: xHCI Host Controller
[    0.917259] usb usb1: Manufacturer: Linux 6.8.0-56-generic xhci-hcd
[    0.917262] usb usb1: SerialNumber: 0000:03:00.3
[    0.918459] hub 1-0:1.0: USB hub found
[    0.926286] usb usb2: We don't know the algorithms for LPM for this host, disabling LPM.
[    0.926388] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 6.08
[    0.926395] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    0.926400] usb usb2: Product: xHCI Host Controller
[    0.926405] usb usb2: Manufacturer: Linux 6.8.0-56-generic xhci-hcd
[    0.926410] usb usb2: SerialNumber: 0000:03:00.3
[    0.927970] hub 2-0:1.0: USB hub found
[    0.933312] xhci_hcd 0000:03:00.4: new USB bus registered, assigned bus number 3
[    0.937002] xhci_hcd 0000:03:00.4: new USB bus registered, assigned bus number 4
[    0.937018] xhci_hcd 0000:03:00.4: Host supports USB 3.1 Enhanced SuperSpeed
[    0.937411] usb usb3: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 6.08
[    0.937418] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    0.937422] usb usb3: Product: xHCI Host Controller
[    0.937426] usb usb3: Manufacturer: Linux 6.8.0-56-generic xhci-hcd
[    0.937429] usb usb3: SerialNumber: 0000:03:00.4
[    0.937979] hub 3-0:1.0: USB hub found
[    0.938987] usb usb4: We don't know the algorithms for LPM for this host, disabling LPM.
[    0.939043] usb usb4: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 6.08
[    0.939049] usb usb4: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    0.939052] usb usb4: Product: xHCI Host Controller
[    0.939056] usb usb4: Manufacturer: Linux 6.8.0-56-generic xhci-hcd
[    0.939066] usb usb4: SerialNumber: 0000:03:00.4
[    0.942044] hub 4-0:1.0: USB hub found
[    1.163421] usb 1-1: new high-speed USB device number 2 using xhci_hcd
[    1.179420] usb 3-1: new high-speed USB device number 2 using xhci_hcd
[    1.303795] usb 1-1: New USB device found, idVendor=0bda, idProduct=5411, bcdDevice= 1.04
[    1.303813] usb 1-1: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[    1.303822] usb 1-1: Product: 4-Port USB 2.0 Hub
[    1.303831] usb 1-1: Manufacturer: Generic
[    1.308907] usb 3-1: New USB device found, idVendor=0bda, idProduct=0129, bcdDevice=39.60
[    1.308919] usb 3-1: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[    1.308926] usb 3-1: Product: USB2.0-CRW
[    1.308933] usb 3-1: Manufacturer: Generic
[    1.308938] usb 3-1: SerialNumber: 20100201396000000
[    1.364717] hub 1-1:1.0: USB hub found
[    1.428210] usb 2-1: new SuperSpeed USB device number 2 using xhci_hcd
[    1.449667] usb 2-1: New USB device found, idVendor=0bda, idProduct=0411, bcdDevice= 1.04
[    1.449678] usb 2-1: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[    1.449685] usb 2-1: Product: 4-Port USB 3.0 Hub
[    1.449691] usb 2-1: Manufacturer: Generic
[    1.468424] usb 3-2: new high-speed USB device number 3 using xhci_hcd
[    1.479599] hub 2-1:1.0: USB hub found
[    1.559827] usb 1-2: new high-speed USB device number 3 using xhci_hcd
[    1.596717] usb 3-2: New USB device found, idVendor=05e3, idProduct=0608, bcdDevice=85.37
[    1.596735] usb 3-2: New USB device strings: Mfr=0, Product=1, SerialNumber=0
[    1.596743] usb 3-2: Product: USB2.0 Hub
[    1.643476] hub 3-2:1.0: USB hub found
[    1.668741] usbcore: registered new interface driver rtsx_usb
[    1.698226] usb 1-2: New USB device found, idVendor=05e3, idProduct=0610, bcdDevice= 4.01
[    1.698243] usb 1-2: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[    1.698252] usb 1-2: Product: USB2.0 Hub
[    1.698258] usb 1-2: Manufacturer: GenesysLogic
[    1.750448] hub 1-2:1.0: USB hub found
[    1.813273] usb 2-2: new SuperSpeed USB device number 3 using xhci_hcd
[    1.828616] usb 2-2: New USB device found, idVendor=05e3, idProduct=0616, bcdDevice= 4.01
[    1.828630] usb 2-2: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[    1.828637] usb 2-2: Product: USB3.0 Hub
[    1.828643] usb 2-2: Manufacturer: GenesysLogic
[    1.862413] hub 2-2:1.0: USB hub found
[    1.891510] usb 2-1.3: new SuperSpeed USB device number 4 using xhci_hcd
[    1.904997] usb 2-1.3: New USB device found, idVendor=0bda, idProduct=8153, bcdDevice=30.00
[    1.905012] usb 2-1.3: New USB device strings: Mfr=1, Product=2, SerialNumber=6
[    1.905021] usb 2-1.3: Product: USB 10/100/1000 LAN
[    1.905028] usb 2-1.3: Manufacturer: Realtek
[    1.905035] usb 2-1.3: SerialNumber: 000001
[    1.923380] usb 3-2.1: new full-speed USB device number 4 using xhci_hcd
[    1.939457] usbcore: registered new device driver r8152-cfgselector
[    2.021067] usb 3-2.1: New USB device found, idVendor=13d3, idProduct=3529, bcdDevice= 1.10
[    2.021084] usb 3-2.1: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[    2.021091] usb 3-2.1: Product: Bluetooth Radio
[    2.021098] usb 3-2.1: Manufacturer: Realtek
[    2.021104] usb 3-2.1: SerialNumber: 00e04c000001
[    2.053282] r8152-cfgselector 2-1.3: reset SuperSpeed USB device number 4 using xhci_hcd
[    2.117188] usbcore: registered new interface driver r8152
[    2.125876] usbcore: registered new interface driver cdc_ether
[    2.131398] usb 3-2.2: new high-speed USB device number 5 using xhci_hcd
[    2.141478] usb 2-2.1: new SuperSpeed USB device number 5 using xhci_hcd
[    2.154314] usb 2-2.1: New USB device found, idVendor=1058, idProduct=25a3, bcdDevice=10.13
[    2.154326] usb 2-2.1: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[    2.154335] usb 2-2.1: Product: Elements 25A3
[    2.154342] usb 2-2.1: Manufacturer: Western Digital
[    2.154349] usb 2-2.1: SerialNumber: 574343374B33484A35375048
[    2.164785] usb-storage 2-2.1:1.0: USB Mass Storage device detected
[    2.165081] scsi host1: usb-storage 2-2.1:1.0
[    2.165288] usbcore: registered new interface driver usb-storage
[    2.168597] usbcore: registered new interface driver uas
[    2.221506] usb 2-2.2: new SuperSpeed USB device number 6 using xhci_hcd
[    2.234457] usb 2-2.2: New USB device found, idVendor=152d, idProduct=0578, bcdDevice= 1.08
[    2.234476] usb 2-2.2: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[    2.234484] usb 2-2.2: Product: LITEON ULTRA 1
[    2.234491] usb 2-2.2: Manufacturer: LITEON ULTRA 1
[    2.234497] usb 2-2.2: SerialNumber: 00000000006BF
[    2.236007] usb 3-2.2: New USB device found, idVendor=0408, idProduct=3046, bcdDevice= 0.03
[    2.236019] usb 3-2.2: New USB device strings: Mfr=3, Product=1, SerialNumber=2
[    2.236026] usb 3-2.2: Product: USB2.0 VGA UVC WebCam
[    2.236033] usb 3-2.2: Manufacturer: Quanta
[    2.236038] usb 3-2.2: SerialNumber:  0x0001
[    2.304487] usb 2-2.3: new SuperSpeed USB device number 7 using xhci_hcd
[    2.317270] usb 2-2.3: New USB device found, idVendor=1058, idProduct=25a3, bcdDevice=10.21
[    2.317286] usb 2-2.3: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[    2.317294] usb 2-2.3: Product: Elements 25A3
[    2.317301] usb 2-2.3: Manufacturer: Western Digital
[    2.317308] usb 2-2.3: SerialNumber: 325347473031594A
[    2.318624] usb-storage 2-2.3:1.0: USB Mass Storage device detected
[    2.318918] scsi host3: usb-storage 2-2.3:1.0
[    2.386443] usb 2-2.4: new SuperSpeed USB device number 8 using xhci_hcd
[    2.400057] usb 2-2.4: New USB device found, idVendor=1058, idProduct=25ee, bcdDevice=40.09
[    2.400066] usb 2-2.4: New USB device strings: Mfr=2, Product=3, SerialNumber=1
[    2.400070] usb 2-2.4: Product: My Book 25EE
[    2.400074] usb 2-2.4: Manufacturer: Western Digital
[    2.400077] usb 2-2.4: SerialNumber: 5647484C3037564B
[    2.400852] usb-storage 2-2.4:1.0: USB Mass Storage device detected
[    2.401023] scsi host4: usb-storage 2-2.4:1.0
[   22.281805] usbcore: registered new interface driver btusb
[   22.314435] usb 3-2.2: Found UVC 1.00 device USB2.0 VGA UVC WebCam (0408:3046)
[   22.355874] usbcore: registered new interface driver uvcvideo
[ 2151.699901] usb 2-2.2: reset SuperSpeed USB device number 6 using xhci_hcd
cat /sys/bus/usb/devices/usb*/power/runtime_status :
suspended
active
active
suspended
Power cable disconnected :
lsusb  -t :
dmesg | tail -n 20
[181191.071707] r8152 2-1.3:1.0 enx00e04d6c9592: Tx status -108
[181191.071719] r8152 2-1.3:1.0 enx00e04d6c9592: Tx status -108
[181191.071727] r8152 2-1.3:1.0 enx00e04d6c9592: Tx status -108
[181191.071736] r8152 2-1.3:1.0 enx00e04d6c9592: Tx status -108
[181191.071747] usb 2-2.2: cmd cmplt err -108
[181191.071982] r8152 2-1.3:1.0 enx00e04d6c9592: Get ether addr fail
[181191.072013] usb 2-1: USB disconnect, device number 2
[181191.072020] r8152-cfgselector 2-1.3: USB disconnect, device number 4
[181191.073525] usb 1-2: USB disconnect, device number 3
[181191.112451] usb 2-2: USB disconnect, device number 3
[181191.112477] usb 2-2.1: USB disconnect, device number 5
[181191.182084] usb 2-2.2: USB disconnect, device number 6
[181191.182461] sd 2:0:0:0: [sda] tag#25 uas_zap_pending 0 uas-tag 1 inflight: CMD
[181191.182480] sd 2:0:0:0: [sda] tag#25 CDB: Synchronize Cache(10) 35 00 00 00 00 00 00 00 00 00
[181191.264834] sd 2:0:0:0: [sda] Synchronize Cache(10) failed: Result: hostbyte=DID_ERROR driverbyte=DRIVER_OK
[181191.336920] sd 2:0:0:0: [sda] Synchronizing SCSI cache
[181191.474243] sd 2:0:0:0: [sda] Synchronize Cache(10) failed: Result: hostbyte=DID_ERROR driverbyte=DRIVER_OK
[181191.487073] xhci_hcd 0000:03:00.3: WARN Can't disable streams for endpoint 0x82, streams are being disabled already
[181191.490627] usb 2-2.3: USB disconnect, device number 7
[181191.526779] usb 2-2.4: USB disconnect, device number 8
error
active
active
suspended
I get LAN via an USB device.
After power cable removed and connected again,  to get again e.g.:  LAN (via USB) connection it is not possible by log out/in, USB cable disconnect, connect again.
Only the following script does help to get again the USB devices (without reboot):
#!/bin/sh
for port in $(lspci | grep USB | cut -d' ' -f1); do
    echo -n "0000:${port}"| sudo tee /sys/bus/pci/drivers/xhci_hcd/unbind;
    sleep 5;
    echo -n "0000:${port}" | sudo tee /sys/bus/pci/drivers/xhci_hcd/bind;
    sleep 5;
done
If further information will be needed, please tell me.
Thank you for support.
