I suspended my laptop [closed the lid] and when I reopened it wifi would not connect. Logout and login did not fix the problem.
My wifi name is not broadcast
The hidden name had all the data included
I had just performed apt update & upgrade
uname -a
Linux Dell-1749 4.4.0-15-generic #31-Ubuntu SMP Fri Mar 18 19:08:31 UTC 2016 x86_64 x86_64 x86_64 GNU/Linux
As part of my investigation I decided to simply close the lid after my reboot. Upon re-opening the lid wifi was restored as it usually is. I’ll investigate logs if this happens again [my gut tells me this was a one off]
After numerous lid closes and re-opens the bulit in wifi on this Dell laptop suspend and resume works perfectly
I've had problems in 15.10 with Wi-Fi causing problems after suspend, but not always. Restarting the network service seems to temporarily restore functionality for me:
sudo service NetworkManager restart or sudo service network-manager restart
Since it was USB, I had to physically remove it and plug it in before it behaved again. You may be able to do the same next time by pressing a physical hardware switch for Wi-Fi, if there is one.
Well I was mistaken about this being a one off. Today at 11:51 I closed my laptop to run some errands; when I opened the lid at 16:15 the wireless connection failed to re-establish. When I examined the network connection icon I noticed that my hidden network was identified, but reconnect was greyed out.Since I didn't have this thread open I decided to attempt to establish a new connection to the same hidden network - this was successful.
Discrepancies noted:
syslog indicates system sleep at 11:51:54 however at 16:15:57 file systems finished syncing
kernlog indicates at 11:51:52 WLC_SCAN error (-22)
authlog indicates lid closed at 11:51:53 and sleep finished AFTER the lid was opened
I'm not exactly certain how to proceed from my investigation:
lspci |grep Network
08:00.0 Network controller: Broadcom Corporation BCM43224 802.11a/b/g/n (rev 01)
uname -a
syslog entries:
Mar 26 11:51:54 Dell-1749 systemd[1]: Starting Suspend...
Mar 26 11:51:54 Dell-1749 systemd-sleep[10509]: Selected interface 'wlp8s0'
Mar 26 11:51:54 Dell-1749 systemd-sleep[10509]: OK
Mar 26 11:51:54 Dell-1749 systemd-sleep[10509]: Suspending system...
Mar 26 16:15:57 Dell-1749 kernel: [ 6609.366590] PM: Syncing filesystems ... done.
Mar 26 16:15:57 Dell-1749 kernel: [ 6609.486018] PM: Preparing system for sleep (mem)
Mar 26 16:15:57 Dell-1749 kernel: [ 6609.486266] Freezing user space processes ...(elapsed 0.002 seconds) done.
Mar 26 16:15:57 Dell-1749 kernel: [ 6609.488384] Freezing remaining freezable tasks... (elapsed 0.001 seconds) done.
Mar 26 16:15:57 Dell-1749 kernel: [ 6609.489620] PM: Suspending system (mem)
Mar 26 16:15:57 Dell-1749 kernel: [ 6609.489682] Suspending console(s) (useno_console_suspend to debug)
Mar 26 16:15:57 Dell-1749 kernel: [ 6609.491076] sd 0:0:0:0: [sda] Synchronizing SCSI cache
Mar 26 16:15:57 Dell-1749 kernel: [ 6609.592458] sd 0:0:0:0: [sda] Stopping disk
Mar 26 16:15:57 Dell-1749 kernel: [ 6610.207139] PM: suspend of devices complete after 717.274 msecs
Mar 26 16:15:57 Dell-1749 kernel: [ 6610.223174] PM: late suspend of devices complete after 16.029 msecs
Mar 26 16:15:57 Dell-1749 kernel: [ 6610.251020] ehci-pci 0000:00:1d.0: System wakeup enabled by ACPI
Mar 26 16:15:57 Dell-1749 kernel: [ 6610.251031] ehci-pci 0000:00:1a.0: System wakeup enabled by ACPI
Mar 26 16:15:57 Dell-1749 kernel: [ 6610.267027] PM: noirq suspend of devices complete after 43.847 msecs
Mar 26 16:15:57 Dell-1749 kernel: [ 6610.267238] ACPI: Preparing to enter system sleep state S3
Mar 26 16:15:57 Dell-1749 kernel: [ 6610.355058] ACPI : EC: EC stopped
kernlog entries:
Mar 26 11:51:52 Dell-1749 kernel: [ 6606.485564] ata1.00: configured for UDMA/100
Mar 26 11:51:52 Dell-1749 kernel: [ 6606.648804] IPv6: ADDRCONF(NETDEV_UP): enp32s0:link is not ready
Mar 26 11:51:52 Dell-1749 kernel: [ 6606.712586] r8169 0000:20:00.0 enp32s0: link down
Mar 26 11:51:52 Dell-1749 kernel: [ 6606.712711] IPv6: ADDRCONF(NETDEV_UP): enp32s0:link is not ready
Mar 26 11:51:52 Dell-1749 kernel: [ 6606.715156] IPv6: ADDRCONF(NETDEV_UP): wlp8s0:link is not ready
Mar 26 11:51:52 Dell-1749 kernel: [ 6606.770087] ERROR @wl_cfg80211_scan : WLC_SCAN error (-22)
Mar 26 16:15:57 Dell-1749 kernel: [ 6609.489682] Suspending console(s) (use no_console_suspend to debug)
authlog entries:
Mar 26 11:17:01 Dell-1749 CRON[25228]: pam_unix(cron:session): session opened for user root by (uid=0)
Mar 26 11:17:01 Dell-1749 CRON[25228]: pam_unix(cron:session): session closed for user root
Mar 26 11:51:43 Dell-1749 systemd-logind[807]: Lid closed.
Mar 26 11:51:50 Dell-1749 systemd-logind[807]: Lid opened.
Mar 26 11:51:50 Dell-1749 systemd-logind[807]: Operation 'sleep' finished.
Mar 26 11:51:51 Dell-1749 dbus[754]: [system] Rejected send message, 10 matched rules; type="method_return", sender=":1.29" (uid=0 pid=3252 comm="/usr/sbin/dnsmasq --no-resolv--keep-in-foreground") interface="(unset)" member="(unset)" error name="(unset)" requested_reply="0" destination=":1.9" (uid=0 pid=760 comm="/usr sbin/NetworkManager --no-daemon ")
Mar 26 11:51:54 Dell-1749 systemd-logind[807]: Lid closed.
Mar 26 16:15:57 Dell-1749 systemd-logind[807]: Lid opened.
Mar 26 16:15:57 Dell-1749 systemd-logind[807]: Operation 'sleep' finished.
Mar 26 16:17:01 Dell-1749 CRON[12577]: pam_unix(cron:session): session opened for user root by (uid=0)
Mar 26 16:17:01 Dell-1749 CRON[12577]: pam_unix(cron:session): session closed for user root
Mar 26 16:20:20 Dell-1749 dbus[754]: [system] Rejected send message, 10 matched rules; type="method_return", sender=":1.29" (uid=0 pid=3252 comm="/usr/sbin/dnsmasq --no-resolv--keep-in-foreground") interface="(unset)" member="(unset)" error name="(unset)" requested_reply="0" destination=":1.9" (uid=0 pid=760 comm="/usr/sbin/NetworkManager --no-daemon ")
@wolfman, Thank you for your continued interest and support! [no need for a screen shot, your explanation makes perfect sense]
I read with interest the link you included. My quandary is this intermittent wifi symptom is happening on the same laptop that has been running Ubuntu 14.04 LTS for almost 2 years [never had this symptom] and has just surfaced while testing UM 16. I’m willing to keep investigating, just not willing to label the symptom a bug as yet.
After UM 16 is fully released and if the same symptoms persist I will, of course, use the script.
So does blank the screen only keep the hard drive and cpu fully active?
