Hi all
I'm running Ubuntu Mate 18.04.2 on Raspberry Pi 3 Model B+ and it works like a charm. I'm trying to get the drivers to work for my 3.5 LCD screen and there are no procedures.
The screen works on the current version of Raspbian but I prefer Ubuntu Mate it's amazing. Has anyone managed to get this screen type working and if so what were the steps please?
There is a procedure for Ubuntu mate 16.04.2 but it doesn't support the new hardware for the Raspberry Pi 3 Model B+ so no luck there.
The Touch screen is 3.5 inch RPi Display 480x320 Pixel XPT2046 Touch controller
If you try to install the driver instead of using their ubuntu mate image with pre-installed driver, it may be somewhat tricky. I managed to bring it to live with an ubuntu-mate-18.04.2-beta1-desktop-armhf+raspi-ext4 image (32bit version, since 64bit is experimental).
I used: git clone https://github.com/waveshare/LCD-show.git
Since executing ./LCD35-show failed, i went through all single commands inside this file. There were a bunch of problems. I had to do things like:
Correct paths if necessary (absolute paths are used, if user is not "/home/pi" you have to modify):
bootloader wasnt able to load kernel (i guess) if config-35c.txt is used as is. I deleted all comments in both files (original "config.txt" in boot partition and the provided one "config-35c.txt") and merged it manually.
to see ubuntu mate desktop on display, change Option "fbdev" "/dev/fb0" to Option "fbdev" "/dev/fb1" in "/usr/share/X11/xorg.conf.d/99-fbturbo.conf"
Better save your current raspberry image before trying this. LCD-show overrides some of your local files without backup, warning or anything.
Not sure if i did everything right, or every step is really necessary, but finally it worked.
Thank you for your info, i was able to install my LCD.
Later i realised that fbcp was a program that duplicate the screen on the hdmi to the lcd.
So i download the git https://github.com/tasanakorn/rpi-fbcp (couldn't install the fbcp included in the waveshare git), i install it and then in ubuntu mate i add a program to the startup which launch "/usr/local/bin/fbcp &". Now i can see the desktop through the hdmi and the lcd at the same time. In /boot/config.txt i can configure the resolution in the line hdmi_cvt. i'm using 1024x768, and i can see that resolution on the lcd. If i start the pi with no hdmi connection i see the desktop also on the lcd.
The lcd screen is a bit slow, but it is usable.
