Hello everyone,
i have an asus eeepc 1015pd seashell that has a problem, it cuts off the bottom part of the screen.
Resolution is set to 1024x768 but the lcd is 1024x600, and seems there is no way to fix the problem (that happens even in the bios, but a connected external monitor is ok, you can see a similar problem, without any solution, here: http://superuser.com/questions/443647/eee-pc-seashell-series-netbook-screen-is-cut-off-at-bottom-no-matter-the-resolut , or here: http://www.tomshw.it/forum/portatili-tablet-e-all-in-one/278172-problema-monitor-tagliato-asus-eee-pc-seashell.html ).
I would like to use ubuntu mate anyway, is the a way to create a blank panel that can’t be overlapped by the windows in the bottom part? (e.g. a rectangle from pixel 0,600 to pixel 1024,768), or even better to restrict the useable area to 1024x600 ignoring the latest 168 pixels? (even xrandr doesn’t seem to be able to create such a resolution).
I have totally disassembled and reassembled the lcd and the cable hoping it was a loose cable but nothing changed.
Thank you in advance.
