@guiverc,
Well, it may not be the most elegant approach, but here is what I did.
The Script [getPkgInfo.sh]:
#!/bin/bash
dbg=0
packageDetails="/Local/PkgInfo"
packageNameList="/Local/PkgList.txt"
packageScanStat="/Local/PkgList.details"
getPackageList()
dpkg-query --list |
tail --lines=+6 |
awk '{ print $2 }'
details_long()
dpkg-query --show --showformat='Package: ${Package}
Depends: ${Depends}
Pre-Depends: ${Pre-Depends}
Description: ${Description}
Status: ${Status}
Architecture: ${Architecture}
Bugs: ${Bugs}
Conffiles: ${Conffiles}
Config-Version: ${Config-Version}
Conflicts: ${Conflicts}
Breaks: ${Breaks}
Enhances: ${Enhances}
Essential: ${Essential}
Filename: ${Filename}
Homepage: ${Homepage}
Installed-Size: ${Installed-Size}
MD5sum: ${MD5sum}
MSDOS-Filename: ${MSDOS-Filename}
Maintainer: ${Maintainer}
Origin: ${Origin}
Priority: ${Priority}
Provides: ${Provides}
Recommends: ${Recommends}
Replaces: ${Replaces}
Revision: ${Revision}
Section: ${Section}
Source: ${Source}
Suggests: ${Suggests}
Tag: ${Tag}
Triggers-Awaited: ${Triggers-Awaited}
Triggers-Pending: ${Triggers-Pending}
Version: ${Version}' "${package}"
details_short()
Depends: ${Depends}
Version: ${Version}
Status: ${Status}
Architecture: ${Architecture}' "${package}" |
awk '{
pos=index( $0, ":") ;
beg=substr( $0, 1, pos-1 ) ;
rem=substr( $0, pos+2 ) ;
if( rem == "" ){
printf("%s: %s\n", beg, "NO_ATTRIB_VAL" ) ;
}else{
printf("%s\n", $0 ) ;
}' | grep -v 'NO_ATTRIB_VAL'
#Bugs: ${Bugs}
#Conffiles: ${Conffiles}
#Config-Version: ${Config-Version}
#Conflicts: ${Conflicts}
#Breaks: ${Breaks}
#Enhances: ${Enhances}
#Essential: ${Essential}
#Filename: ${Filename}
#Homepage: ${Homepage}
#Installed-Size: ${Installed-Size}
#MD5sum: ${MD5sum}
#MSDOS-Filename: ${MSDOS-Filename}
#Maintainer: ${Maintainer}
#Origin: ${Origin}
#Provides: ${Provides}
#Recommends: ${Recommends}
#Replaces: ${Replaces}
#Revision: ${Revision}
#Section: ${Section}
#Size: ${Size}
#Source: ${Source}
#Suggests: ${Suggests}
#Tag: ${Tag}
#Triggers-Awaited: ${Triggers-Awaited}
#Triggers-Pending: ${Triggers-Pending}
if [ -s "${packageNameList}" ]
then
rm -i "${packageNameList}"
fi
if [ ! -s "${packageNameList}" ]
then
getPackageList >"${packageNameList}"
gvim "${packageNameList}"
fi
#mode=long
mode=short
count=$(wc -l "${packageNameList}" | awk '{ print $1 }' )
if [ ! -f "${packageScanStat}" ]
then
if [ ${dbg} -eq 1 ]
then
head -5 "${packageNameList}"
else
tac "${packageNameList}"
fi |
while read package
do
printf "\t [${count}] ${package} ...\n"
details_${mode} >${packageDetails}/${package}.${mode}.txt 2>${packageDetails}/${package}.${mode}.err
test -s ${packageDetails}/${package}.${mode}.err || rm -f ${packageDetails}/${package}.${mode}.err
count=$(expr ${count} - 1 )
done
touch "${packageScanStat}"
ls -l ${packageDetails} | more
fi
grep 'gtk-2' ${packageDetails}/*.${mode}* >PkgList.gtk2.txt
grep 'gtk-3' ${packageDetails}/*.${mode}* >PkgList.gtk3.txt
grep 'gtk-4' ${packageDetails}/*.${mode}* >PkgList.gtk4.txt
The output files [typical; one per installed package]:
PkgInfo/acpid.short.txt
Package: acpid
Description: Advanced Configuration and Power Interface event daemon
Modern computers support the Advanced Configuration and Power Interface (ACPI)
to allow intelligent power management on your system and to query battery and
configuration status.
ACPID is a completely flexible, totally extensible daemon for delivering
ACPI events. It listens on netlink interface (or on the deprecated file
/proc/acpi/event), and when an event occurs, executes programs to handle the
event. The programs it executes are configured through a set of configuration
files, which can be dropped into place by packages or by the admin.
Depends: libc6 (>= 2.34), lsb-base (>= 3.2-14), kmod
Pre-Depends: init-system-helpers (>= 1.54~)
Priority: optional
Version: 1:2.0.33-1ubuntu1
Status: install ok installed
Architecture: amd64
The Library Compatibility Scan [one per library; partial]:
/Local/PkgInfo/font-manager.short.txt:Depends: font-manager-common (= 0.8.8-1), font-viewer (= 0.8.8-1), dconf-gsettings
-backend | gsettings-backend, libc6 (>= 2.34), libglib2.0-0 (>= 2.53.2), libgtk-3-0 (>= 3.22), libjson-glib-1.0-0 (>= 1.
5.2), libpango-1.0-0 (>= 1.37.5), libsoup2.4-1 (>= 2.41.90), libsqlite3-0 (>= 3.5.9), libwebkit2gtk-4.0-37 (>= 2.25.1)
/Local/PkgInfo/gir1.2-javascriptcoregtk-4.0:amd64.short.txt:Package: gir1.2-javascriptcoregtk-4.0
/Local/PkgInfo/gir1.2-javascriptcoregtk-4.0:amd64.short.txt:Depends: gir1.2-glib-2.0, libjavascriptcoregtk-4.0-18 (= 2.4
4.2-0ubuntu0.22.04.1)
/Local/PkgInfo/gir1.2-webkit2-4.0:amd64.short.txt:Depends: gir1.2-javascriptcoregtk-4.0 (= 2.44.2-0ubuntu0.22.04.1), lib
webkit2gtk-4.0-37 (= 2.44.2-0ubuntu0.22.04.1), gir1.2-gtk-3.0, gir1.2-soup-2.4
/Local/PkgInfo/gnome-builder.short.txt:Depends: exuberant-ctags, gir1.2-ggit-1.0 (>= 0.28.0.1), gir1.2-glib-2.0 (>= 1.62
.0), gir1.2-gtk-3.0 (>= 3.24), gir1.2-gtksource-4 (>= 4.0.0), gir1.2-jsonrpc-1.0 (>= 3.30.1), gir1.2-peas-1.0 (>= 1.22.0
), gir1.2-webkit2-4.0 (>= 2.26), python3-gi, libvala-dev, clang, gir1.2-dazzle-1.0 (>= 3.37.0), gir1.2-template-1.0 (>=
3.28.0), gir1.2-vte-2.91 (>= 0.65.0), dconf-gsettings-backend | gsettings-backend, python3:any, libatk1.0-0 (>= 1.12.4),
libc6 (>= 2.34), libcairo-gobject2 (>= 1.10.0), libcairo2 (>= 1.10.0), libclang1-14 (>= 1:5.0~svn298832-1~), libcmark0.
30.2 (>= 0.30.2), libdazzle-1.0-0 (>= 3.37.0), libdevhelp-3-6 (>= 3.20.0), libenchant-2-2 (>= 2.2.3), libflatpak0 (>= 1.
11.2), libfontconfig1 (>= 2.12.6), libgirepository-1.0-1 (>= 0.9.2), libgit2-1.1 (>= 1.1.0), libgit2-glib-1.0-0 (>= 0.28
.0.1), libgladeui-2-13 (>= 3.22.0), libglib2.0-0 (>= 2.70.0), libgspell-1-2 (>= 1.8.2), libgtk-3-0 (>= 3.24), libgtksour
ceview-4-0 (>= 4.0.0), libhandy-1-0 (>= 1.5.90), libjson-glib-1.0-0 (>= 1.5.2), libjsonrpc-glib-1.0-1 (>= 3.41.0), libpa
ngo-1.0-0 (>= 1.38.0), libpangocairo-1.0-0 (>= 1.38.0), libpangoft2-1.0-0 (>= 1.38.0), libpcre3, libpeas-1.0-0 (>= 1.22.
0), libportal-gtk3-1 (>= 0.5), libportal1 (>= 0.5), libsoup2.4-1 (>= 2.41.90), libsysprof-4 (>= 3.37.90), libsysprof-ui-
4 (>= 3.37.90), libtemplate-glib-1.0-0 (>= 3.28.0), libvte-2.91-0 (>= 0.66.1), libwebkit2gtk-4.0-37 (>= 2.26), libxml2 (
>= 2.9.0)
It isn't elegant, but it's a start!
Wish there was something better integrated with our package managers of choice. Any takers out there ?
Where I was headed with this was to put a spotlight on packages that are NOT compliant with a library version so as to render visible and raise awareness of where some attention might be needed.
