When working with LO Calc each time I save Calc and other LO opened documents freeze for a little while and CPU usage jumps.
Seems a memory issue to me
Anybody here facing the same issue ? ... and found a way to address it ?
I am on UM 23.04 64 bits Kernel 6.2.0-27 M 1.26.0
It only happens to me when I use the LO Snap version, if you have installed that one, try installing LO from apt, or try installing the Flatpak version. Sorry for my English, I find myself learning it.
UM22.04.3 using LO 7.5.5.2 directly from website. My repository still showing 7.3 version. Just another option. Works fine but not tested here with a very large file. Would tend to agree with @javialveo90 on snap if you are using it.
