After a day of searching, I’m stuck trying to find this feature ;
I have a spreadsheet that uses colour shading for different strings or values. I just want to print the contents and gridlines in black and white, without any of the colour shading in the cells. In MS Office, this is easy, you just select print black and white.
In Libreoffice, I can’t find this option anywhere.
It’s not in File - Printer Settings
It’s not in File - Print Preview
It’s not in Tools - Options - Libreoffice Calc - Print
Is there actually an option available, in 2017, to allow someone to print a spreadsheet in LibreOffice Calc without having it spew toner over the entire page reproducing cell shading?
Thanks for the reply Rigo. No need to apologise for your english!
I’m amazed that this isn’t an option. I’ve looked everywhere. (In Excel it’s a simple tickbox, “print black and white”.)
The sheet has conditional formatting as well as regular colour-coding of cells. Your workaround’s one way of doing it for sure, - but it’s frustrating to have to do that every time you need to print the sheet, which in my case is a lot.
Here’s hoping that it’s a “feature” that gets some attention soon.
