Continuing the discussion from 19.10 freezing when Firefox hits 100% CPU:
Having major issues with LO on my MATE desktop. Please refer to the thread and posts via the link and thanks to all who have responded there.
LO freezing when trying to open a very simple PDF file in Draw. Forced to do hard reboot as cannot even use Force Quit to unlock it.
LO froze as well when I went in to un-toggle the graphics acceleration box under General Settings>View. Again, forced to do hard reboot.
I have uninstalled LO via Software Boutique and downloaded the most recent version of LO from the website. 6.3.3.2. Loaded fine and the 2 instances above happened again.
Any advice on this would be appreciated. Computer works absolutely fine when not using LO and we are now using Google Docs, Sheets and Slides as our workaround. Obviously would be far better to be able to use LO as it should be used.
One last point. We CAN use LO if we create or open simple docs, spreadsheets etc that don't have images in them or if we don't try to insert an image.
Thanks in advance for any assistance on this.
