Hi
I have a problem with 16.04. When I’m logging in to my computer, the background in LightDM Greeter is just blank white until the moment when I log in, then for a second or so it turns to the background image I’ve selected in the settings. Does anyone have any idea how to fix this?
Hi @Qnth,
have you run all updates?:
@wolfman Hello,
Yes, I believe so. Going through that guide I find no updates available on my system. I’ve had this problem for a while now actually, I updated from 14.04 a while back, and after that upgrade the problem appeared. I’ve even tried changing the background from the multihead setup -tool, but to no avail. It’s not really a huge problem for me, as I rarely reboot or log out, but it’s annoying still.
