Hi Everyone I have this pretty complicated issue that I have been dealing with for years and I don't really know how to fix it. This is a problem I only have under linux so it's not an issue with my build. I built a computer with an ASUSTek PRIME A320M-K motherboard following this guide : https://linux-hardware.org/?probe=4ccbcf1ee5 and a Ryzen 3 cpu. Almost immediately I noticed under linux I was having issues. Several times a day the entire computer would become unresponsive. I thought at first it was a hardware thing but then I started testing under windows and never had an issue with freezing or the system locking up.
Someone also seemed to have a similar issue here: [SOLVED] Machine locks up after 16-48 hours. / Newbie Corner / Arch Linux Forums
I have read so many pages and articles: Disable cstates C6, make modifcations to your bios, update your firmware, change out your kernel.... I am trying to figure out how to organize all this and do some logical troubleshooting of this issue. I tried disabling the C6 ( I think I did it right ) but that didn't seem to help. Does anyone know how to troubleshoot or fix this kind of issue?
