I am being asked for a login and password on a first boot of Ubuntu mate 1910 any ideas for a fix for this?
Thanks
Ger
Thanks
Ger
Go to Control Panel > Administration > User > Allow manual login and Username.
Or Administration > Users and Groups > Password > Asked at login > Change
Watch when installing, when you set the password there is a box to check, not asked at login.
If for some reason you don't have users and groups, installing "gnome-system-tools" will provide that administration function.
Thanks Jymm
I may have omitted to say that i am logging in from a Raspberry Pi and its through a terminal that i am trying to login form so no access to the image just yet.
However I think there was issues with the image that I was using (obtained from Raspberrypi.org
) and I have now installed a better more reliable image from the download section here.
Thanks again for the help
Ger
