I have a set of Logitech G930 wireless headphones that I use with every piece of equipment I have. It works with the desktop, on Android phones and tablets, and on the Raspberry Pi 3… unless I use OMXPlayer. I know its got to do with OMXPlayer having only audio settings for HDMI, Local, or Auto.
I’m wondering what the prompt command would be to tell OMX to send audio to the G930 Headphones. Essentially, what would replace the ??? in the following command?
omxplayer -o ??? Scooby\ Doo\ Mystery\ Incorporated\ S02E15\ Theater\ of\ The.Doomed\ 720p\ Salman\ Sk\ Silver\ RG.mp4
Again, I do want to point out that the headphones do work when just plugged in on everything else, so if anyone is wondering, Yes you can use them with RPi3.
