I lost my printer utility. It doesn't appear on the launcher menu any longer and the printer does not respond to print requests from apps (i.e. Libre Office) when I open LibreOffice Writer for example and open a saved document and select "Print" The printer shows up as MFC-L2705DW but noyhing happens
Brother MFC-L2705DW
Connected directly on LAN (cat5)
Shows as a device on the router.
Shows up on apps as an installed printer
Works fine on Windows
Could this be a CUPS problem?
BTW - printer has worked as it should for many years.
Printer stopped working when I installed MATE 1.26.0
I reinstalled MATE 1.24.0 still no joy.
Any suggestions to bring back my printer would be appreciated.
8/21/21 - additional info. I noticed that the printer indicates that its in "Deep sleep" mode. Doesn't affect operating normally in Windows OS. but UM still doesn't print. I guess the system in either case should send a command to wake up.
