Hello everyone
I have problem with ubuntu mate ltsp client usb printer and scanner is not working. can anyone help me.
Thanks in advance
Regards
Hello everyone
Thanks in advance
Regards
Looks vague.
What is Ubuntu version on LTSP client (or in rootfs image)?
Do you administer LTSP server?
What is printer / scanner model?
Do you have cups
, simple-scan
(or xsane
) in LTSP image?
Do you see the USB device in lsusb
Can you setup printer in system-config-printer
Can you see scanner in scanimage -L
Ubuntu Mate 16.04 desktop PNP LTSP configured
client pxe boot load ltsp image
ubuntu mate 16.04 have cups and simple-scan
Printer EPSON LQ-300+ Scanner HP DESKJET 1050
If i login form client 'USB device' is not showing in lsusb
is not detecting usb printer
Can not you see scanner in scanimage -L
I can recommend to debug these printer and scanner from ordinary Ubuntu 16.04 LTS.
Determine the needed packages or firmware and then install these components to the LTSP client.
For DESKJET 1050 the installation of hplip
and hplip-gui
packages seems to be enough.
Do not know about LQ-300.
