Hi everyone,
I was able to install Mate 22.x on my old Macbook Pro late 2010.
Previous version worked well, an error I had with the wnck-applet disappeared and I was able to use the wifi drivers from the standard packages, tricky but funny.
Unfortunately the last upgrade killed my system, it no longer boots. Error reading somewhere and just getting a prompt for an emergency shell.
I did the upgrade with synaptic, not sure if this has done something not appropriate for the hardware.
Maybe I need to take care of something non-standard before any upgrade. I’ve always trust on the default.
No clue what I may do at the emergency shell, the only options I know are, trying a recover from the master usb/iso or to reinstall from scratch. If there is any other option, It will be appreciated
Thanks in advance
Macpilot
