Hello everybody,
I’m currently considering installing Ubuntu Mate with the hopes that it will resolve the extreme thermal issues with my late 2011 MacBook Pro. The MacBook was recently hit by the common issue of the discrete AMD graphics chip failing and in order to even get the laptop to boot into MacOS I had to remove some of the files required to load the chip fully.
Unfortunately without some of those files either the chip remains active in the background drawing maximum power causing the laptop to get incredibly hot. With only one YouTube video playing in full screen the laptop quickly reaches low to mid 90C with just 10% CPU usage.
Some people have managed to find older versions of those files which resolved the thermal issue for them, but I don’t have access to these older files.
Is there a better way in Ubuntu Mate to fully disable the AMD chip and only run on intel graphics?
The discrete AMD chip would also need to be disabled as soon as possible while installing Ubuntu Mate because as soon as the chip gets triggered the laptop locks up fully.
Any help would be greatly appreciated.
