The installer seems to get stuck at the Injecting loader step, also whenever I click on the browse button to change the discord install directory everything is in squares as if I am missing a font. The error dialogue boxes pop up with the same issue.
I should see if I don’t already have content for Bandaged BetterDiscord, and if not, to make it exist.
All comments above refer to a previous iteration and does not reflect current iteration.
I tested the steps in my current iteration, and BetterDiscord works fine. Installs correctly the first time and so long you make the path BBD expects to put stuff it won’t cause any major errors which cripple your use of the desktop client.
