Making something happen at logout
###My brain hurts.
I’ve been screwing around trying to improve how my system handles login and logout tasks with no success whatsoever, so I give up; How can I do it?
I also want users to be able to edit this script easily so some way to have a script execute from ~ would be ideal.
Do you want to create a script to be manually executed like for example:
espeak goodbye
mate-session-save --logout
Or do you want to change permanently what the system does every time you logout (that would be awesome!)?
Permanently modify what the system does, and make it per-user so users can add their own logout (and maybe even login) scripts via some tweaks to some files in home.
There is so much conflicting information, but I think pam is a good first thing to try out. I’ve attempted to make something happen with pam by adding my script in /etc/pam.d and doing chmod a+x to make it usable but no joy came from that, not even when I try tor use pam_exec.so to run the thing I want. (I even tried commands directly rather than shell files, not sure if that’s kosher.)
At this point? I’m like Whatever works, yo.
Never knew about espeak. Hurray, a new thing for me to play with! :slight_smile:
I took some info from "Adding System Hooks" section here: https://wiki.ubuntu.com/LightDM and I managed to do something similar by adding the line:
session-cleanup-script= sh -c "espeak goodbye"
at my /etc/lightdm/lightdm.conf file. I don't know but, is it possible to make different lightdm configurations per user? Also, according to the link above, session-cleanup-script is executed after user's session ends, so possible it may cause problems if you try to modify user's files in the executed script.
EDIT: You need to restart lightdm to take effect (sudo systemctl restart lightdm).
Is that it? Because when I had that in my lightdm.conf file I ended up stuck at the splash screen; Nothing else would happen!
Anything else I need to do so that my script doesn’t make my system die?
Well I just discovered these stuff, I have no idea. If you can please share the script you use and I will take a look and if I can understand any of it, I may give some ideas (4 eyes are always better than 2 :stuck_out_tongue:) .
Apparently this doesn’t work good, because in my example, even if you just select another user at the lightdm greeter (after you logout) then espeak gets activated again. I think the answer lies at systemd. Can you take a look here: http://askubuntu.com/questions/293312/execute-a-script-upon-logout-reboot-shutdown-in-ubuntu at “HOW TO DO IT WITH SYSTEMD” answer?
