good day sir please if i type in sudo apt-get update this is what it shows me
E: Malformed entry 1 in list file /etc/apt/sources.list.d/archive_uri-https_repo_mysql_com_apt_ubuntu-jammy.list (absolute Suite Component)
E: The list of sources could not be read.
Line 1 of the file /etc/apt/sources.list.d/archive_uri-https_repo_mysql_com_apt_ubuntu-jammy.list contains an error which needs to be corrected.
We're limited to details you provide (ie we can't know what's in that file, as you provided only the error message); but whomever added it (it's not a standard file, so someone on your system with sudo rights added it) added a incorrectly formatted file. Edit the file and correct the error(s).
Please note; that line was treated as an EOF (End Of File) because of the error, thus other errors in the file could exist; the processor ignored subsequent lines on encountering the first error; so check the whole file for problems.
The directory /etc/ requires elevated or sudo privileges, but use whatever editor you're familiar with (eg. I'd use vim, but others will use nano or ... etc)
