Like Martin I am running MATE 15.10 on an INTEL NUC with a core i7 processor. It’s hooked up to a 27 inch Dell running 2560x1440.
I will gladly post my technical review later on, however I wanted to know if anyone can tell me how to get my login screen to a decent resolution? the GTK greeter configurator does not have any resolution options and I didn’t want to muck around the config files.
So I followed wolfman’s instructions, the greeter resolution is still
1024x768 using the script. I didn’t have a lighted.conf file so I created
one. There is a users.con and a lighted-greeters-gdm.conf file. Should that
script setting be in one of these files? However after I login the screen
resolution goes to the default from the script created. Although this is
minor, I can’t seem to install the mint display manager, due to a conflict.
In addition, with switching to gdm from lightdm, that breaks the entire
login greeter system. I used “dpkg-reconfigure lightdm”.
What is the recommended login manager for MATE? Can I apply themes to it?
Does it have a way to set the resolution in a config file? Should we use
GDM instead of lighted for configurability?
I really like the flat look desktops and themes, such as Numix so I am
trying to customize the greeter with a flat login screen and Numix or flat
desktop theme.
Right now I am testing both 15.10 and your 16.04 beta in a VM before
installing or upgrading 15.10 on the NUC.
