Installing Ubuntu-MATE 18.04 LTS takes me to GRUB and eventually to a Login screen, nothing I do allows me to boot directly to Login screen.
I bought a new desktop computer. It is a System76 model Wild Dog Pro with SSD and HDD, and a
DVD. The computer arrived in working order with System76's installed Ubuntu. The new computer
has an Intel i5-8400 CPU at 2.8GHZ x 6. Linux is on the SSD (three partitions - Boot, Linux & Swap),
the HDD currently has my empty partitions, not really used now.
My other older computers run Ubuntu-MATE 16.04 LTS, the version I like. The new computer will not
run the Ubuntu-MATE 16.04 LTS, I guess the newer computer is not compatible with 2016 vintage
software. The Ubuntu-MATE people released the new 18.04 LTS. I downloaded and booted to a Live
version and performed some tests - It appeared good, so I performed an Install of that version to the
new computer.
Then, doing a re-boot and the Boot Loader is not working. I get a GRUB prompt. Typing "exit" takes
me to another screen where the computer slowly tries various options of sources. The displayed third
line changes and eventually, about five minutes, I get a normal Ubuntu boot screen and from what I can
tell Ubuntu 18.04 works just fine. Photos of those screens are included. Everything I try to get the
Boot Loader to work so I can just login to Ubuntu fails.
Typing "exit & Enter" gives me the next screen
After about five minutes a normal Ubuntu-MATE login screen appears.This computer has Ubuntu 18.04 LTS (Bionic Beaver) 64-bit installed which is Kernel Linux 4.15.0-
20-generic x86_64 with MATE 1.20.1.
I tried numerous ideas to rectify this, but nothing works.
The computer appears to be UFEI computer, per article Repair GRUB the Flags column includes “boot,
esp”The instructions in that article fail at sudo mount /dev/sda1 /mnt/boot/efi so I terminated
that process.
Tried running "grub-install" process from a 7 year old article, the option "root-partition" is not valid
anymore. So, this didn't work.
Tried downloading and running tool Boot Repair which always fails - it says it fails.
So, how can I get my Boot Loader (or what ever) to run so it Boots Linux? Any ideas.
