Last weekend I did a project that involved making two huge wav files in the my documents folder as I stripped them from a video, nothing complicated and the system filled up the SSD and said low memory etc. This got deleted and all was well in regards to that project.
The following day however the computer has loaded up the icons and picture on the desktop about 20 seconds after boot up and entering the desktop environment. The icon and desktop image load up time was usually 1 second flat. I have uninstalled and reinstalled MATE to no difference. Entering Ubuntu 20.04 which was installed a fresh with no upgrade in its original form via gnome shows the desktop load time as normal i.e. 1 second flat. I have done the commands for removing and reinstalling the swap file as well as running bleachbit. I have also tested the SSD using the Disks program extended disk check feature, it shows its ok.
I run the memory test no the startup for the RAM and it stopped on the vert first test within seconds of it starting at 47%
However upon testing each stick separately they all passed with no errors. I put the ram back in where they were and it errors at 47% again. I tried shuffling the sticks to find on another it stopped at 58% and then I worked out with just one stick left, luckily 4gb, I could see it pass the first test without an issue. So, kinda strange, its obviously not the ram causing the MATE issue but for some reason they suddenly don't like being with each other.
Any ideas? Thanks in advance.
