I recently installed the ubuntu-unity-desktop
and ubuntu-budgie-desktop
but didn't like them. So I deleted them using sudo apt purge
and sudo apt autoremove
. After doing this, my PC still shows the ubuntu unity logo while booting and shutting down. Also, I still have the option to change desktop environments while logging in and when I log into MATE my panel is all messed up and doesn't even fix when I reset all panels.
I guess it would be fair to say that although some may suggest certain things that you should do, the damage has already been done [and it's likely gonna take an eternity dealing with that]. If I were you, I'll make my life easier by backing my files up and reinstalling.
That's my two cents. I don't like dealing with multiple desktops in a single setup either. If you didn't like that, maybe we can both wait for someone else. I'm similarly keen on what they may have to offer.
Could you show us the output of:
sudo apt update
sudo dpkg --configure -a
sudo apt-get install -fy
sudo apt-get autoclean
sudo apt-get autoremove --purge -y
sudo apt full-upgrade -y
Do you think that reinstalling ubuntu-mate-desktop
(not definitely) may fix broken parts?
You mean I should boot into recovery mode, remove it then install it again ?
Well, I think removing it is not mandatory. Just apt reinstall ...
would suffice if the problem can be fixed that way.
Unfortunately, that hasn't fixed anything
Hit:1 http://gb.archive.ubuntu.com/ubuntu noble InRelease
Hit:2 http://gb.archive.ubuntu.com/ubuntu noble-updates InRelease
Hit:3 http://security.ubuntu.com/ubuntu noble-security InRelease
Hit:4 https://deb.opera.com/opera-stable stable InRelease
Hit:5 http://gb.archive.ubuntu.com/ubuntu noble-backports InRelease
Hit:6 https://download.docker.com/linux/ubuntu noble InRelease
Hit:7 https://tvd-packages.tradingview.com/ubuntu/stable jammy InRelease
Hit:8 https://repo.steampowered.com/steam stable InRelease
Hit:9 https://dl.google.com/linux/chrome/deb stable InRelease
Hit:10 https://packages.microsoft.com/repos/code stable InRelease
Reading package lists... Done
Building dependency tree... Done
1 package can be upgraded. Run 'apt list --upgradable' to see it.
0 to upgrade, 0 to newly install, 0 to remove and 1 not to upgrade.
Calculating upgrade... Done
Get more security updates through Ubuntu Pro with 'esm-apps' enabled:
vlc-plugin-qt libvlc5 freerdp2-x11 vlc-data bettercap libvlccore9 vlc restic
vlc-bin libwinpr2-2t64 vlc-l10n libcjson1 libavdevice60 ffmpeg libpostproc57
vlc-plugin-samba libavcodec60 libavcodec60 vlc-plugin-notify libavutil58
libavutil58 libswscale7 libfreerdp-client2-2t64 vlc-plugin-access-extra
vlc-plugin-skins2 vlc-plugin-video-splitter libswresample4 libswresample4
vlc-plugin-video-output libavformat60 libfreerdp2-2t64 libvlc-bin
vlc-plugin-base vlc-plugin-visualization libavfilter9
Learn more about Ubuntu Pro at https://ubuntu.com/pro
The following upgrades have been deferred due to phasing:
ubuntu-drivers-common
Bad lead.
At login screen, can you check if you can select the guest login? Don't select the guest and ensure you login to your user.
Yes, I can select it.
You appear to be asking/complaining about seeing the plymouth
screen for a removed flavor, that is really just a wallpaper and isn't removed when you purge the package, as if you had no others available you'd be getting an error; thus all metapackages tend to skip that, rather than have specially coded logic that detects if it can be removed (ie. others exist on your file-system; users would likely see that as invading privacy anyway; so code isn't there)..
You just select another plymouth screen to be used; that occurs automatically when you install new ones, but just kick that process off yourself. Does a wasted few hundred KB (maybe a MB) of disk space for a picture/text file really worry you? You can just manually remove those files without issue too.
This maybe rough; gotta depart now
Does everything else work ?
Go to /usr/share/xsessions/
and remove redundant launchers.
At a guess: there's some leftover material in /usr/share/plymouth/themes/
. You can look at where the default is pointing via:
sudo update-alternatives --query default.plymouth
The line
Value: /usr/share/plymouth/themes/ubuntu-mate-logo/ubuntu-mate-logo.plymouth
tells you, essentially, what theme it is using (in my example, MATE's).
Does this mean you can log in to other sessions still? I would expect not, and in this case, I'd do as @ironfoot suggested, and look for redundant entries in /usr/share/xsessions/
You might be able to get the correct behaviour by fixing up the panel, then going to MATE Tweak -> "Panel" -> "Save as" - for a new custom configuration.
It might seem annoying, but I find it a lot easier to test different desktops in a virtual machine (virt-manager makes this relatively easy) rather than risk messing up my day-to-day OS.
