Hi, just upgrade my 22.04 to 24.04 and the mate-dock-applet stopped working
"it is there" as I it collides with other applets but it shows nothing: Imgur: The magic of the Internet
I tried running
python3 /usr/lib/mate-applets/mate-dock-applet/dock_applet.py
in the console to see if there are any error messages but there are no logs or outputs
I have no idea how to move forward. Any help will be appreciated. Thanks!
Solved!
For some reason this was loaded at startup, I think maybe a conflict with plank?
Dock Reload
Reload the dock during session start-up to correctly align with panel struts
Command: /usr/lib/ubuntu-mate/dock-replace
Removing it from startup fixed the issue
Hi Augustin, good to see you managed to solve it.
Could you click on the checkbox at the bottom of your second post, to flag that as the solution for all to see that
- it has been resolved, and
- you provide the solution to the issue encountered.
Thank you.
