After unplanned shutdown of my PC the advanced MATE Menu is not on the panel any more (I'm using redmond styled panel) .
I was trying to recover it by:
- mate-panel --reset
- sudo apt-get install mate-core mate-desktop-environment mate-notification-daemon
- sudo apt-get install --reinstall mate-core mate-desktop-environment mate-desktop-environment-extras
But without success. ...
When I tried to run it by hand I got this replay:
$ mate-menu
bash: /usr/bin/mate-menu: /usr/bin/python2: bad interpreter: No such file or directory
I even reinstall python with :
sudo apt install python --reinstall
All without luck. How to get it back?
Thanks
D.
