This is a little off topic but I thought I might ask anyway. I have an old netbook that I wanted to see if I could use it. Naturally I wanted to install Ubuntu-MATE on it. But the processor is only 32-bit. So I installed Debian with the MATE desktop. It actually works pretty well. One thing is missing, however. I would really like to setup the "netbook" panel layout from U-M. Is there a script or guide to doing this or am I on my own?
Thanks for any help,
Bill
Welcome back to the Ubuntu MATE community, @Bill!
Currently you have only one variant to get 32-bit UM - install 18.04 LTS. But many user-space applications from third-parties are more and more 64-bit only. So you may have problems in near feature with 32-bit OS.
Could please specify full model number of the processor and/or laptop? How much RAM it has?
If you can please show the full output of lscpu
command.
Did you tried to run 64-bit OS on this laptop?
lscpu
results:
Architecture: i686
CPU op-mode(s): 32-bit
Byte Order: Little Endian
Address sizes: 32 bits physical, 32 bits virtual
CPU(s): 2
On-line CPU(s) list: 0,1
Thread(s) per core: 2
Core(s) per socket: 1
Socket(s): 1
Vendor ID: GenuineIntel
CPU family: 6
Model: 28
Model name: Intel(R) Atom(TM) CPU N270 @ 1.60GHz
Stepping: 2
CPU MHz: 1424.673
CPU max MHz: 1600.0000
CPU min MHz: 800.0000
BogoMIPS: 3191.87
L1d cache: 24K
L1i cache: 32K
L2 cache: 512K
Flags: fpu vme de tsc msr pae mce cx8 apic sep mtrr pge mca cmov pat clflush dts acpi mmx fxsr sse sse2 ss ht tm pbe nx constant_tsc arch_perfmon pebs bts cpuid aperfmperf pni dtes64 monitor ds_cpl est tm2 ssse3 xtpr pdcm movbe lahf_lm dtherm
Netbook is a Dell Mini-9 aka Inspiron 910 with 2 GB. Never tried installing a 64-bit OS.
I am fine with running Debian. I would just like to get the desktop looking and running more like U-M with Netbook panels. I find the default Debian settings rather annoying.
Thanks for the quick response,
Bill
I see, it is really 32-bit.
I would recommend to test Ubuntu MATE 18.04 LTS from LiveCD/LiveUSB first.
It supports 32-bits and is still supported.
Thanks, 18.04 works fine. Hope it gets supported for a while.
Bill
The Ubuntu base has almost three years of support left, the MATE portion only 1 year, but I would not worry about that.
