Mate panel app - Is it possible activate "minimize on click"?
as title said, it would be very helpful for me to activate this feature regarding icon apps on top panel of mate. Is there a way?
Edit. maybe I could insert a proper command into every launcher properties to do it?
Hi @Lt_Franck_Drebin,
"minimize on click" is a common feature for a dock application. Ubuntu Mate comes with Plank dock (enable in MATE Tweak) and panel Dock applet (add to panel via context menu).
So, you may add a dock, put there your favourite launchers and enjoy "minimize on click" functionality.
Good luck!
Or just add the 'show desktop' applet to your panel. It's one of the first things I do on a fresh install.
Very thanks for your support
