This is one of the little annoyance that avoid me maybe fully go through Ubuntu Mate.
At work as i am not using computers under MS Windows i always bring my own laptop and use VGA connection to connect to 1900x1200 screens resolutions (maybe 1900 x 1080 not sure)
Screens are working ok and i set up those as primary monitors and turn off the laptop’s screen.
With any DE (Gnome / kde Plasma / Unity) all the setup are just fine, same as i configured on the laptop.
With Mate and i’ll say unfortunately, i have to manually move all the applet i put in panel to get back to my original settings, to make working those panels in the same way as they appear (proportionally) on my laptop’s screen. The resolution is fine but the searching tool, date, time for instance are not in the place they should be.
Is there any way to get those being in the right place ?
As always, i apologize for my non-fluently English
