Hi, everyone!
I'm running Ubuntu MATE 18.04 LTS (64-bit) - "18.04.3 LTS (Bionic Beaver)" - on a Laptop / Notebook. It has all the Software Updates (Operating System Updates) installed, according to the "Software Updater" (" The software on this computer is up to date. ").
A few days ago, I had to change from the "Familiar" Panel Layout to the "Traditional" one, in this computer, due to some "Brisk menu" crashes. That change apparently solved the problem with the "Brisk menu" crashes, but today (8 Dec 2019) I started having a crash dialog related to "mate-power-manager" after I log in my computer with my local user account.
The version of the component/package is "mate-power-manager 1.20.1-2ubuntu1"
My kernel is 5.0.0-37
The error message (Title) present in the crash dialog window is the following:
Title: mate-power-manager crashed with signal 7 in elf_machine_rela_relative()
In case it is relevant, the "XsessionErrors" present in the crash dialog window are as follows:
XsessionErrors:
mate-session[1908]: WARNING: Unable to find provider '' of required component 'dock'
(process:2461): indicator-sound-WARNING **: 22:17:46.484: volume-control-pulse.vala:744: Unable to connect to dbus server at 'unix:path=/run/user/1000/pulse/dbus-socket': Could not connect: No such file or directory
(process:2461): indicator-sound-WARNING **: 22:17:46.601: accounts-service-access.vala:218: unable to sync volume 0,317749 to AccountsService: GDBus.Error:org.freedesktop.DBus.Error.InvalidArgs: No such interface 'com.ubuntu.AccountsService.Sound'
(mate-panel:2360): GLib-GObject-CRITICAL **: 22:17:47.488: g_object_unref: assertion 'G_IS_OBJECT (object)' failed
(nm-applet:2435): Gtk-WARNING **: 22:17:47.689: Can't set a parent on widget which has a parent
(nm-applet:2435): Gtk-CRITICAL **: 22:17:48.763: gtk_widget_destroy: assertion 'GTK_IS_WIDGET (widget)' failed
(nm-applet:2435): Gtk-WARNING **: 22:17:48.828: Can't set a parent on widget which has a parent
(nm-applet:2435): Gtk-CRITICAL **: 22:17:48.898: gtk_widget_destroy: assertion 'GTK_IS_WIDGET (widget)' failed
(nm-applet:2435): Gtk-WARNING **: 22:17:48.990: Can't set a parent on widget which has a parent
Is anyone else here experiencing the same issue?
