Mate Tweak, option to keep applets added when changing layout?
When you change the panel layout, any customization reverts to default; is there any chance to add an option to keep the applets and custom launchers when changing the panel layout?
TIA
Yeah, I noted that as well. I lost all of my custom icons, which were quite a few in mumber. Not a major deal, but a slight irritation.
That is on the roadmap, but I’ve not decided how to implement it yet.
Thanks @Wimpy
Maybe restoring the customizations could be the default action and a checkbox to “restore to default”?
Edit: or reverse; default when you change panels and a check box to keep the customizations…
there just should be a button like ‘apply’. before it’s clicked nothing should be changed because user may not like and any system crash should not enforce any changes
i also lost indicators, icons, multiple desktop settings, primary screen settings. just don’t auto-apply anything, it’s against UX.
