I am not sure if the drive is recognized properly. Audio CDs or DVDs are not playing. Do I need to install any separate drivers or change anything in the Mount Options?
Old laptop DVD/CD drives are notorious for failing, one moment they will work and then go on strike, make sure you clean with a CD cleaner and remove the drive, boot the laptop, shut down the laptop and replace the drive and then reboot and I bet it will work again (for one or two times at least!).
I removed the DVD drive and booted into UM 16.04, then shut down the laptop. I put the drive back in and booted again but the DVD drive still doesn’t recognize any media. I know this DVD drive is not without problems but it was working under my previous Windows installation, so I guess there must be a way to get it to work under UM 16.04. Any other ideas?
Try booting Ubuntu Mate from a USB stick and then put a music CD in the drive and see if it plays!.
I have had this problem myself quite recently whereby the disk drive would sometimes be there and then on the next boot; be gone!. This happened with Windows and Linux!.
I just tried it with several music CDs but the drive won’t recognize any. In Disks the DVD drive is always visible. Am I missing any drivers or do I need to mount it manually?
I just checked these settings in the Dconf Editor and it is exactly the same. I also set it back to the default settings. Music CDs and DVDs still won’t play. In Disks it always says No Media.
Is there anything else I can do? @wolfman@ouroumov
I am quite sure that it was working before and replacing the drive would really be the last option. Do you have any ideas about this @lah7?
Since you say it worked perfectly under Windows, I suspect it’s a firmware issue. I know a modern Apple USB SuperDrive for example refuses to spin media on Linux unless a specific hex command is sent to the drive first. Something similar could be happening here… particularly as it says “No Media” and not “Unknown”.
If the computer is able to boot from a disc, then I’d be sure it’s just a firmware issue between the OS and not a fault of the drive itself.
