This is a little script I made for Caja.
- Calculates MD5, SHA-1, and SHA-2 checksums
- can handle multiple files (creates a checksum file)
- has a progress bar
Requirements: zenity, pv
xsel (optional)
Install the script in /home/username/.config/caja/scripts/ and make executable (chmod 755)
#!/bin/bash
# Purpose: Caja Custom Action. Calculates hashes.
# Version: 1.3 (January 2017) - Misko_2083
# Licence: GPLv2
if ! hash zenity &>/dev/null ; then
echo "zenity is not installed!"
echo "please install zenity"
exit 1
fi
if ! hash pv &>/dev/null ; then
echo "pv is not installed!"
echo "please install pv"
zenity --error --text="pv is not installed\nplease install pv"
exit 1
fi
MD5=(`echo "" | awk '{print "TRUE","MD5", $0}'`)
SHA1=(`echo "" | awk '{print "FALSE","SHA-1", $0}'`)
SHA224=(`echo "" | awk '{print "FALSE","SHA-224", $0}'`)
SHA256=(`echo "" | awk '{print "FALSE","SHA-256", $0}'`)
SHA384=(`echo "" | awk '{print "FALSE","SHA-384", $0}'`)
SHA512=(`echo "" | awk '{print "FALSE","SHA-512", $0}'`)
progressbar(){
read PIPED_PID
zenity --progress --title="${1} Checksum" \
--text="Calculating ${1} for:\n${file##*/}" --auto-close \
|| (kill $PIPED_PID; rm $sum_temp)
do_md5(){
((pv -n "$file" | md5sum 2>&1 | tee >(cut -d ' ' -f1 > $sum_temp) 2>&1 \
| awk '{if ($1 <=99) print $1; else print 99; fflush(stdout)}')& echo $!) 2>&1 \
| progressbar "MD5"
# If Cancel is clicked then exit
if [[ ! -f "$sum_temp" ]]; then
exit 0
fi
show_results "MD5"
do_sha1(){
((pv -n "$file" | sha1sum 2>&1 | tee >(cut -d ' ' -f1 > $sum_temp) 2>&1 \
| progressbar "SHA-1"
exit 0
fi
show_results "SHA-1"
do_sha224(){
((pv -n "$file" | sha224sum 2>&1 | tee >(cut -d ' ' -f1 > $sum_temp) 2>&1 \
| progressbar "SHA-224"
exit 0
fi
show_results "SHA-224"
do_sha256(){
((pv -n "$file" | sha256sum 2>&1 | tee >(cut -d ' ' -f1 > $sum_temp) 2>&1 \
| progressbar "SHA-256"
exit 0
fi
show_results "SHA-256"
do_sha384(){
((pv -n "$file" | sha384sum 2>&1 | tee >(cut -d ' ' -f1 > $sum_temp) 2>&1 \
| progressbar "SHA-384"
exit 0
fi
show_results "SHA-384"
echo $selection | grep "SHA-512" > /dev/null
do_sha512(){
((pv -n "$file" | sha512sum 2>&1 | tee >(cut -d ' ' -f1 > $sum_temp) 2>&1 \
| progressbar "SHA-512"
exit 0
fi
show_results "SHA-512"
show_results(){
sum=`cat $sum_temp`
if zenity --question --title="$1" \
--text="$1 : $sum\nFile : ${file##*/}\n
If you have a correct checksum on clipboard you can compare it with this one.
Do you want to compare?" --no-wrap
then
# Compare with clipboard
sum_paste="$(zenity --entry --title="Compare sum" \
--text="If xsel is installed it will paste into text entry box automatically.Enter the sum to compare:" \
--entry-text="$(xsel -b -o 2>/dev/null || echo "Paste Here")"
if [ $? = 0 ]; then
if [ "$sum_paste" == "$(cat $sum_temp)" ];then
zenity --info --title="${1}" --text="Checksums are IDENTICAL!" --icon-name="gtk-yes"
else
zenity --info --title="${1}" --text="Checksums are DIFFERENT!" --icon-name="gtk-no"
fi
fi
fi
selection_dialog(){
selection=$(zenity --list --radiolist --height=300 \
--title="Checksum" --text="File: <b>${file##*/}</b>\nPick the hash function." \
--column="Pick" --column="Hash" \
"${MD5[@]}" "${SHA1[@]}" "${SHA224[@]}" "${SHA256[@]}" "${SHA384[@]}" "${SHA512[@]}")
if [ "${PIPESTATUS[0]}" -ne "0" ]; then
exit 0
fi
# Create a temp file
sum_temp=$(mktemp /tmp/sum.XXXXXXXX)
case "${selection}" in
"MD5") do_md5 ;;
"SHA-1") do_sha1 ;;
"SHA-224") do_sha224 ;;
"SHA-256") do_sha256 ;;
"SHA-384") do_sha384 ;;
"SHA-512") do_sha512 ;;
esac
multi_checksum(){
case "${1}" in
"MD5") md5sum "${2}" >> md5.checksum ;;
"SHA-1") sha1sum "${2}" >> sha1.checksum ;;
"SHA-224") sha224sum "${2}" >> sha224.checksum ;;
"SHA-256") sha256 "${2}" >> ha256.checksum ;;
"SHA-384") sha384sum "${2}" >> sha384.checksum ;;
"SHA-512") sha512 "${2}" >> sha512.checksum ;;
esac
do_multi(){
if zenity --question --title="${1} Checksumsum" --no-wrap \
--text="Multiple files selected.\nThis will create/overwrite a file named <b>${2}.checksum</b>
in the directory where the selected files are stored.
Proceed?"
then
> ${2}.checksum
i=0
TOTAL="$counter"
while read -r line || [[ -n "$line" ]]; do
((++i))
PERCENT=$(($i*100/${TOTAL}))
echo "#${2} $i/$TOTAL: $line"
multi_checksum "${1}" "${line}" >&1
echo "$PERCENT"
done < "$LST" | zenity --progress --title="${1}" --auto-close
exo-open "${2}.checksum" 2>/dev/null || zenity --text-info --title="${1} checksums" < ${2}.checksum
fi
selection_dialog_multi(){
--title="Checksum" --text="Pick the hash function." \
exit 0
fi
"MD5") do_multi "MD5" "md5" ;;
"SHA-1") do_multi "SHA-1" "sha1" ;;
"SHA-224") do_multi "SHA-224" "sha224" ;;
"SHA-256") do_multi "SHA-256" "sha256" ;;
"SHA-384") do_multi "SHA-384" "sha384" ;;
"SHA-512") do_multi "SHA-512" "sha512" ;;
esac
LST=$(mktemp /tmp/XXXXXX)
> $LST
for arg
do
if [[ -f "${arg}" ]]; then
echo ${arg} >> $LST
fi
done
counter="$(wc -l "$LST" | cut -d' ' -f1)"
case "${counter}" in
""|0) zenity --error --text="Nothing to calculate!" ;;
1) file="$@"; selection_dialog ; rm $sum_temp;;
*) selection_dialog_multi ;;
esac
rm $LST
#End of script
This does not mean that everything that comes with a Md5 or sha1 checksum is dangerous - but you should be aware that there is an element of risk. As always, think-before-you-click-before-you-install.
