Hi, I have come across the same issue, icons on getting displayed, after upgrading Ubuntu 20.04 from Ubuntu 18.04.
The below-mentioned solution worked for me. It might work for others as well:
The issue might have occurred because the installation did not go according to the plans.
The simplest, easy and the most effective operation you can do is:
sudo apt dist-upgrade
This will automatically install/update/repair all the needed packages for your current version.
