Hi guys , new to the forum .
I tried to look for a similar issue, but I can’t find it. I just started with mate and setup a 7 inch display. updated and before and after update I still am missing a bottom portion as if an inch of the screen is cut off. I can’t seem to change any display settings so hopefully somebody can point me in the right direction even?
Is there anything I can provide to help troubleshoot this?
That sounds like your display settings is now wrong. Have you tried different settings by going to system/preferences/hardware/displays?
Hi @deigratia86,
what hardware (monitor) are you using, it might help find an answer?.
@wolfman Hi! Thanks for a response. I purchased the 7 inch touch screen from raspberry pi org . I reviewed their documentation and can’t find a similar situation or problems. I figured this would be a good place to start.
This may be a linux problem, since it was behaving this way with raspbian as well. I think @stevecook172001 might be right about display settings. I’ll check in to that as well.
Thanks a ton to you both for responses.
