I loaded “Desktop Games” from the Ubuntu Mate (in 16.04.3) Welcome Software Boutique because it had Mahjongg.
When I had Mahjongg in Ubuntu 12.04, it had a dozen tile layouts. This one seems to only have one called “Easy”, otherwise it seems identical.
Where can I get the other layouts?
I installed it thus but I think it was the one I already had via "Desktop Games":
$ sudo apt install mahjongg
The following NEW packages will be installed
mahjongg
0 to upgrade, 1 to newly install, 0 to remove and 399 not to upgrade.
Need to get 14.5 kB of archives.
After this operation, 61.4 kB of additional disk space will be used.
Get:1 http://es.archive.ubuntu.com/ubuntu xenial/universe amd64 mahjongg all 1:3.18.0-1 [14.5 kB]
Fetched 14.5 kB in 0s (23.3 kB/s)
Selecting previously unselected package mahjongg.
(Reading database ... 274491 files and directories currently installed.)
Preparing to unpack .../mahjongg_1%3a3.18.0-1_all.deb ...
Unpacking mahjongg (1:3.18.0-1) ...
Setting up mahjongg (1:3.18.0-1) ...
$ sudo apt install gnome-mahjongg
Reading package lists... Done
Building dependency tree
gnome-mahjongg is already the newest version (1:3.18.0-1).
0 to upgrade, 0 to newly install, 0 to remove and 399 not to upgrade.
This what the top of my Mahjongg screen looks like when I run it. How does it compare with yours? I can't see any way of changing the layout.
